Having trouble with theis interface EEM applet
hfakoor222
I'm trying to monitor interface traffic in a GNS environment with both a c7200 and an IOU. I continue getting Incomplete Command errors via several variations of applying transmit traffic EEM commands. The receive commands work fine, but I want to look at the traffic exiting the interface.
For example this works fine:
event interface name Ethernet0/3 parameter receive_rate_bps entry-op ge entry-val 80000000 entry-type value poll-interval 10
and this shows incomplete command
event interface name Ethernet0/3 parameter transmit_rate_bps exit-op ge exit-val 80000000 exit-type value poll-interval 10
any ideas?
I've spent almost an hour trying to figure it out, so I thought it was time to ask for some help.
event [tag event-tag] interface name interface-type interface-number parameter counter-name entry-op operator entry-val entry-value entry-type {value | increment | rate} poll-interval poll-int-value [exit-comb {or | and}] [exit-op operator exit-val exit-value] [exit-type {value | increment | rate}] [exit-time exit-time-value] [average-factor average-factor-value] [maxrun maxruntime-number]
I think there is not poll-int-value, you need exit-time instead
