HDLC VS eoMPLS /MPLS
daniel45793
HI
im learning ccent from the cisco book
i cant understand what the differen betweent HDLC to eoMPLS /MPLS
if someone can explain this
and if someone can explain to me what they do (i know what they do but perfectly) just so i will understand this 100%
thanks (:
Richard Burts
To start with the simple one: HDLC is a layer 2 protocol used for point to point serial interfaces. It is significant that it is for communication between 2 devices. As the layer 2 protocol it coordinates functions such as clocking on the serial link, and evaluating the received bits and checking to make sure that no bit was lost in transit or changed in transit.
MPLS is for providing communication between multiple devices, or multiple networks. While HDLC operates only at layer 2 MPLS operates at layer 3 and provides routing information to support data sent from one network to other networks.
eoMPLS is intended to provide typical Ethernet services using an MPLS network as its transport.
Rick
Rick
Richard Burts
Rick
Rick
