help for cisco 1711 internet connection
debgallup
I have a 1711 that has been working fine till last friday. 10 computers connected thru hub. 1 computer connects fine to internet all other 9 get "web sit found" waiting for reply. google site comes up, then when you search you click on any results and web site found waiting for reply. Any ideas would be appreciated. Have cycled router multiple times. replaced dsl modem, sbc says no problem. replaced hub. replaced cables. Has to be in Cisco. Any suggestions would be helpful.
Danilo Dy
Please post the router config (remove username/password/shared-key).
Dandy
route config attached.
thanks, for any info you can provide.
