Help With - OutOfRange::Component=VOLT
Jacob Berger
Level 5
Level 5
I am getting the following critical message
EVENT DESCRIPTION       = OutOfRange::Component=VOLT-172.24.1.253/3054 [Te1/5/4 Supply Voltage Sensor];ComponentClass=VoltageSensor;ComponentEventCode=1080;HighThreshold=5.0;Status=OK;CurrentValue=6.5;LowThreshold=1.0;entSensorValue=65;RelativeVoltageThreshold=0.0 %;
NOTIFICATION ORIGINATOR = Fault Management Module
is this a real problem and how can this be corrected ?
9 Replies 9
Marvin Rhoads
I have that seen that problem reported by LMS on an ASR router. At the time, it was identified as a bug (CSCtc18926) when I opened a TAC case.
Others have reported it with 10 Gbps interfaces. Search this forum for "VoltageSensor" and you will see several postings. I'd open a TAC case and in the meantime try Joe Clarke's suggestion in this thread:
https://supportforums.cisco.com/message/3260929#3260929
in my case the voltage is 6.5 above the high threshold and not 0 as in Joe Clarke's suggestion
will see what cisco has to say...
Joe's suggestion was to address the point of unmanaging an individual component for which DFM or the Fault Management Module is giving erroneous readings.
You should first verify that your device itself believes the actual value to be within specification. Usually some variation of "show environment" on the end device will reveal the built-in thresholds.
tried "show environment" but didnt see anything about the above component, maybe i am missing something?:
environmental alarms:
  no alarms
backplane:
  operating clock count: 0
  operating VTT count: 0
switch 1 fan-tray 1:
  switch 1 fan-tray 1 type: WS-C6509-E-FAN
  switch 1 fan-tray 1 mode: Restricted-power
  switch 1 fan-tray 1 fan-fail: OK
switch 2 fan-tray 1:
  switch 2 fan-tray 1 type: WS-C6506-E-FAN
  switch 2 fan-tray 1 mode: Restricted-power
  switch 2 fan-tray 1 fan-fail: OK
switch 1 VTT 1:
  switch 1 VTT 1 OK: OK
  switch 1 VTT 1 outlet temperature: 30C
switch 1 VTT 2:
  switch 1 VTT 2 OK: OK
  switch 1 VTT 2 outlet temperature: 27C
switch 1 VTT 3:
  switch 1 VTT 3 OK: OK
  switch 1 VTT 3 outlet temperature: 30C
switch 2 VTT 1:
  switch 2 VTT 1 OK: OK
  switch 2 VTT 1 outlet temperature: 29C
switch 2 VTT 2:
  switch 2 VTT 2 OK: OK
  switch 2 VTT 2 outlet temperature: 30C
switch 2 VTT 3:
  switch 2 VTT 3 OK: OK
  switch 2 VTT 3 outlet temperature: 28C
VTT 10:
  VTT 10: not available
VTT 11:
  VTT 11: not available
VTT 12:
  VTT 12: not available
switch 1 clock 1:
  switch 1 clock 1 OK: OK, switch 1 clock 1 clock-inuse: in-use
switch 1 clock 2:
  switch 1 clock 2 OK: OK, switch 1 clock 2 clock-inuse: not-in-use
switch 2 clock 1:
  switch 2 clock 1 OK: OK, switch 2 clock 1 clock-inuse: in-use
switch 2 clock 2:
  switch 2 clock 2 OK: OK, switch 2 clock 2 clock-inuse: not-in-use
switch 1 power-supply 1:
  switch 1 power-supply 1 fan-fail: OK
  switch 1 power-supply 1 power-input: AC high
  switch 1 power-supply 1 power-output-mode: high
  switch 1 power-supply 1 power-output-fail: OK
switch 1 power-supply 2:
  switch 1 power-supply 2 fan-fail: OK
  switch 1 power-supply 2 power-input: AC high
  switch 1 power-supply 2 power-output-mode: high
  switch 1 power-supply 2 power-output-fail: OK
switch 2 power-supply 1:
  switch 2 power-supply 1 fan-fail: OK
  switch 2 power-supply 1 power-input: AC high
  switch 2 power-supply 1 power-output-mode: high
  switch 2 power-supply 1 power-output-fail: OK
switch 2 power-supply 2:
  switch 2 power-supply 2 fan-fail: OK
  switch 2 power-supply 2 power-input: AC high
  switch 2 power-supply 2 power-output-mode: high
  switch 2 power-supply 2 power-output-fail: OK
switch 1 module 1:
  switch 1 module 1 power-output-fail: OK
  switch 1 module 1 outlet temperature: 35C
  switch 1 module 1 inlet temperature: 26C
switch 1 module 2:
  switch 1 module 2 power-output-fail: OK
  switch 1 module 2 outlet temperature: 27C
  switch 1 module 2 inlet temperature: 25C
  switch 1 module 2 device-1 temperature: 26C
  switch 1 module 2 device-2 temperature: 30C
switch 1 module 3:
  switch 1 module 3 power-output-fail: OK
  switch 1 module 3 outlet temperature: 34C
  switch 1 module 3 inlet temperature: 30C
  switch 1 module 3 device-1 temperature: 26C
  switch 1 module 3 device-2 temperature: 33C
  switch 1 module 3 aux-1 temperature: 31C
  switch 1 module 3 aux-2 temperature: 31C
switch 1 module 4:
  switch 1 module 4 power-output-fail: OK
  switch 1 module 4 outlet temperature: 33C
  switch 1 module 4 inlet temperature: 26C
  switch 1 module 4 device-1 temperature: 26C
  switch 1 module 4 device-2 temperature: 34C
switch 1 module 5:
  switch 1 module 5 power-output-fail: OK
  switch 1 module 5 outlet temperature: 38C
  switch 1 module 5 inlet temperature: 26C
  switch 1 module 5 device-1 temperature: 30C
  switch 1 module 5 device-2 temperature: 32C
  switch 1 module 5 asic-1 temperature: 56C
  switch 1 module 5 asic-3 temperature: 41C
  switch 1 module 5 asic-4 temperature: 55C
  switch 1 module 5 RP outlet temperature: 30C
  switch 1 module 5 RP inlet temperature: 30C
  switch 1 module 5 EARL outlet temperature: 33C
  switch 1 module 5 EARL inlet temperature: 27C
switch 2 module 1:
  switch 2 module 1 power-output-fail: OK
  switch 2 module 1 outlet temperature: 36C
  switch 2 module 1 inlet temperature: 27C
switch 2 module 2:
  switch 2 module 2 power-output-fail: OK
  switch 2 module 2 outlet temperature: 26C
  switch 2 module 2 inlet temperature: 26C
  switch 2 module 2 device-1 temperature: 26C
  switch 2 module 2 device-2 temperature: 30C
switch 2 module 5:
  switch 2 module 5 power-output-fail: OK
  switch 2 module 5 outlet temperature: 38C
  switch 2 module 5 inlet temperature: 26C
  switch 2 module 5 device-1 temperature: 30C
  switch 2 module 5 device-2 temperature: 33C
  switch 2 module 5 asic-1 temperature: 57C
  switch 2 module 5 asic-3 temperature: 41C
  switch 2 module 5 asic-4 temperature: 52C
  switch 2 module 5 RP outlet temperature: 28C
  switch 2 module 5 RP inlet temperature: 29C
  switch 2 module 5 EARL outlet temperature: 31C
  switch 2 module 5 EARL inlet temperature: 26C
  chassis connector rating: 1302.00 Watts (31.00 Amps @ 42V)
switch 1 module 1
  switch 1 module 1 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 1 module 1 power consumption:  325.50 Watts ( 7.75 Amps @ 42V)
switch 1 module 2
  switch 1 module 2 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 1 module 2 power consumption:  125.16 Watts ( 2.98 Amps @ 42V)
switch 1 module 3
  switch 1 module 3 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  switch 1 module 3 power consumption:  171.78 Watts ( 4.09 Amps @ 42V)
switch 1 module 4
  switch 1 module 4 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  switch 1 module 4 power consumption:  163.80 Watts ( 3.90 Amps @ 42V)
switch 1 module 5
  switch 1 module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  switch 1 module 5 power consumption:  338.10 Watts ( 8.05 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  switch 1 module 1 cooling requirement: 70 cfm
  switch 1 module 2 cooling requirement: 70 cfm
  switch 1 module 3 cooling requirement: 30 cfm
  switch 1 module 4 cooling requirement: 70 cfm
  switch 1 module 5 cooling requirement: 35 cfm
  switch 2 module 1 cooling requirement: 70 cfm
  switch 2 module 2 cooling requirement: 70 cfm
  switch 2 module 5 cooling requirement: 35 cfm
Ah OK, it's a transceiver voltage alarm. In that case, the transceiver needs to be of the type that supports Digital Optical Monitoring (DOM) (see this listing).
If it is, you will be able to use the command "show interface transceiver detail" as shown here:
show interface Te5/1 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te5/1       26.4                75.0        70.0         0.0       -5.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te5/1      3.31                  3.60        3.50        3.10       3.00
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te5/1       -2.4                 1.6        -1.3        -7.3      -11.3
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te5/1       -3.5                 1.9        -1.0        -9.9      -13.9
how can i find which Transceiver Module i have?
this is the output
under voltage its all N/A
Transceiver monitoring is disabled for all interfaces.
Te1/5/5      26.8                74.0        70.0         0.0       -4.0
Te1/5/5      N/A                   N/A         N/A         N/A        N/A
            Current            Threshold   Threshold  Threshold  Threshold
Port        (milliamperes)     (mA)        (mA)       (mA)       (mA)
Te1/5/5      39.8         --     N/A        N/A        N/A       N/A
Te1/5/5      -1.3                 4.4         0.4        -8.2      -12.2
Te1/5/5      -4.4                 4.4         0.4       -14.4      -18.4
Is it a Cisco transceiver or 3rd party?
If it's Cisco, it looks like the SFP is not reporting its voltage value properly - it's either an implementation bug on the hardware burned-in chip or else it may need to be RMA'd.
(Your output is for te1/5/5 and the original post was for 1/5/4 - are they both reporting the error?)
Its a Cisco transceiver (dont remember model)
Yes both are reporting the same.
It may help to look at:
.1.3.6.1.4.1.9.9.91.1.1.1.1.4
entSensorValue OBJECT-TYPE
     -- FROM     CISCO-ENTITY-SENSOR-MIB
     -- TEXTUAL CONVENTION SensorValue
     SYNTAX          Integer (-1000000000..1000000000)
     MAX-ACCESS     read-only
     STATUS          Current
     DESCRIPTION    "This variable reports the most recent measurement seen
        by the sensor.
        To correctly display or interpret this variable's value,
        you must also know entSensorType, entSensorScale, and
        entSensorPrecision.
        However, you can compare entSensorValue with the threshold
        values given in entSensorThresholdTable without any semantic
        knowledge.
From Ciscoworks server CLI , navigate to NMSROOT/objects/smarts/bin
sm_snmpwalk --community=
--oid=.1.3.6.1.4.1.9.9.91.1.1.1.1.4
