hi
sajeer9745
if i have two isp provider and i want to have a primary line and backupline,how can control the flow from myside to the provider and coming back from the provider
marce1000
 - Design final solution in cooperation with the provider ; because there will probably be multiple options.
M.
Deepak Kumar
As I can understand, you are looking a solution for WAN output and input packets flow control as like today data centers are managing traffic flow. If yes than BGP is a solution for you.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
