High CPU Utilization
mustafa.basim85
Frequent Visitor
Frequent Visitor
Hi everyone ,
I have router 6509 , it's working as BGP router. the upload goes through the main provider but i have a certain network which i want to route it's upload to another provider so i created a route-map role but when i apply the role, the CPU of the router 6509 goes up to 85% and when i disable the role the CPU goes normal. does anyone knows what is the issue causing the CPU to goes up ??
harishc12
Visitor
Can you please confirm if "IP route-cache policy" is applied where the route map is applied...
Also please go through the below link...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/configuration/xe-3se/3850/iri-xe-3se-3850-book/iri-fast-switched-policy-rtg.pdf
