High Proxy CPU Usage
krlanglic
Frequent Visitor
Frequent Visitor
I have two cisco wsa S690 v11.5 which always monitor the proxy cpu usage (due to the great quantity of connections per second since a couple of times we received slowness). Today I was very surprised since one of the WSA reported 156.7% of proxy cpu usage. Is this normal?. I know that it only last for some seconds, but I would like to know if a device can report more than the 100% of proxy capacity and if this has any limit.
In order to make sure of this proxy report from the web appliance, I get into the proxystat from CLI. I didn't see it anymore. So may be a difference between them, however, if this may be an issue from the device or appliance?
Best,
Karla
luis_cordova
Hi @krlanglic ,
I have read in some forums that the first recommendation is to update the IOS version.
I leave a link with the latest versions for your device:
https://software.cisco.com/download/home/286290962/type/283998384/release/6.6
Regrads
Hi!
Thanks for the information.
How can I know that version from my WSA. At this time, I'm thinking upgrading the ASYNCOS to 11.5.1-120.
However, how may I know the differences between both releases? The one you sent mention a different version (6.X) Where do i see the version?
Karla
