Historical graphs of router interfaces
jcockburn
Hi All,
How can I get historical utilization graphs of router interfaces in pdf or other format in PI
Ciao
JC
AFROJ AHMAD
Hi ,
Run the below report ::
Report > Report Launch Pad > Device > Interface Availability
you will see the option to "Save and Export"
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
jcockburn
I think I should have included more detail of what I want...
How can I get historical utilization graphs of router interfaces in pdf or other format in PI.
Sort of like the MRTG graphs...
ciao
JC
try running the " Interface Utilization report"
Report >  Report Launch Pad  > Device  > Interface Utilization
Thanks-
Afroz
That is unfortunatly not what I want. I want to see a graph for the last (eg) 24 hours' utilization for a WAN link.
If you give that little table from the report you mentioned to the execs they dont understand. They want to see the graph for the previous day, to see how close we are to congestion during certain times in the day....
I can get the graph on monitoring but you cannot export this to pdf etc....
Looks like a really easy and simple requirement that Prime cannot do....
Please advise
Ciao
