hope you can help me
danny022
I am in search for routers than can support multiple hotspots or that I can see the data or traffic consumed in each SSID, I just need a counter for traffic consumed per network, hopefully I can find a solution with this devices, any device that can provide the info that is requested, please corroborate this to me.
Thanks in advance,
hi, more than bandwidth it's related with data counter and data traffic, looking forward to see at the at a certain period of time how much traffic was used or set limits to how much traffic you can use... I've heard that it is possible with this devices, I don't know if it needs additional software or what else could be used to achieve this need of mine.
I hope you can still help me, thanks in advance.
the AX150 is the device, the business dashboard is the software you want...
balaji.bandi
adding to other suggestion :
consider Meraki good dashboard and more secure feature and cloud management. (if that works for you)
BB
