01-03-2011 08:43 PM
How can I get the total number of switches & routers from LMS
Solved! Go to Solution.
01-04-2011 12:07 PM
The easiest way is to go to Common Services > Device and Credentials > Device Management, and check the boxes next to the Routers and Switches and Hubs device type groups. The total number will be shown at the bottom of the device selector interface.
Posted from my mobile device.
01-04-2011 12:07 PM
