LMS and kaspersky antivirus
ayman emara
Hi All,
I want to install Kaspersky antivirus on LMS server 3.0 .
Thanks in advance,
Ayman Yehia
2 Accepted Solutions
Michel Hegeraat
Level 7
Level 7
Prepare for performance hit
Make sure to exclude the CSCOpx directory from the on access scan.
Cheers,
Michel
If the server is standalone and you allow acces to only LMS GUI then it is pretty hard for the server to get infected.
Allow from users only TCP 1741 443 and 42344
From devices SNMP TFTP TELNET SSH RCP SYSLOG and what else you use
I scan my servers from time to time but no antivirus doing on access scan is enabled on there.
Cheers,
Michel
Michel Hegeraat
Level 7
Level 7
Cheers,
Michel
Hi Michel,
do you know which ports lms is gonna be allowed and does it efficient to put antivirus or their is another method to protect the server from viruses to avoid installing the antivirus and have a performance shock as you've said.
Thanks in advance.
Ayman
Cheers,
Michel
Thanks Michel,
I'll get back to you if i needed help
thanks again
Ayman
