How do i configure more IPs on DHCP Lease
chilemdh
Good Evening,
i increased the dhcp network scope from 192.168.1.0/24 to 192.168.0.0/22 on a cisco 1941 router  ... My PCs can connect to DHCP and internet but my polycom phones are unable to register to polycom after getting IP Address in the range 192.168.0.x?
balaji.bandi
what exact IP get to the Phone full IP address, you have increased the pool have you updated the NAT ACL ? (before it was only translating for 192.168.1.0/24,. not it changed to 192.168.0.0/22
post the config also to understand still have issue.
BB
Martin L
should phones have another subnet and different vlan from data?   anyway, if phones getting IPs, then there might be another issue. Investigate  polycom registration since you mentioned "unable to register to polycom"
Regards, ML
**Please Rate All Helpful Responses **
