How do I confiure my router such that my accessing my public ip internally translates to the correct private IP.
chilipadiboy
Hi guys,
I have a problem with my web application. I cannot access it from my internal network using my static public IP (i.e 49.123.456.7). However I can access it from an external network using my static public IP. Is there a way for me to allow access internally as well as externally?
I am using Cisco 800 series router. Here is my configuration:
Header 1
Current configuration : 2549 bytes
! Last configuration change at 09:35:38 SGT Thu Oct 18 2012 by xxxxx
! NVRAM config last updated at 16:56:45 SGT Wed Oct 17 2012 by xxxxx
version 15.0
no service pad
hostname Router01
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone XXX X
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.222
ip dhcp pool NetworkPool
   import all
   network 192.168.1.0 255.255.255.0
   dns-server XXX.XXX.XXX.66 XXX.XXX.XXX.66
   default-router 192.168.1.1
ip cef
no ip domain lookup
ip domain name nacache1.m1net.com.sg
ip name-server XXX.XXX.XXX.66
login block-for 30 attempts 5 within 10
login delay 3
login quiet-mode access-class 23
no ipv6 cef
license udi pid CISCOXXX-XXX sn XXXXXXXXXXX
username admin privilege 15 secret X ************************.jgis1
policy-map NGNBN
class class-default
  set cos 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
duplex auto
speed auto
interface FastEthernet4.1103
description WAN_Link_100MbpsFibreBiz
encapsulation dot1Q 1103
ip address dhcp
ip nat outside
ip virtual-reassembly
no cdp enable
service-policy output NGNBN
interface Vlan1
description LocalLAN
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT_Addresses interface FastEthernet4.1103 overload
ip nat inside source static tcp 192.168.1.198 80 49.123.456.7 80 extendable
ip nat inside source static tcp 192.168.1.198 443 49.123.456.7 443 extendable
ip nat inside source static tcp 192.168.1.198 8090 49.123.456.7 8090 extendable
ip access-list extended NAT_Addresses
permit ip 192.168.1.0 0.0.0.255 any
access-list 23 remark ** Managment_Segment **
access-list 23 permit XXX.XXX.0.0 0.0.0.255
access-list 23 permit XXX.XXX.XXX.0 0.0.0.255
access-list 23 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
privilege level 15
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
scheduler max-task-time 5000
ntp server XX.XXX.XXX.1 prefer
ntp server XXX.XXX.XXX.81
end
Any help and suggestions will be appreciated
Adeeb
15 Replies 15
Is the IP 49.123.456.7, is your application IP?
Can you provide the traceroute for the IP 49.123.456.7 if yes.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hey Adeeb,
Logically thinking If you trying for a public IP i.e.., you Server with Public IP, You device will try to access the WAN interface and searches the Internet and then it will come to know it is available at the you office network and comes back to your WAN interface where you have a command IP NAT outside for the IP which you are trying hence a loop.
Thanveer
Hi Thanveer,
Thanks for your reply. However I cannot provide a traceroute because my actual public ip leads to sensitive info. Anyway what I can tell you is that it is resolved by my ISP's DNS.
Anyway it may seem like logical thinking however in reality what is happening is that my private IP is translated to my public IP when going into the internet which then redirects it back to my public IP. So technically I am "surfing myself". Thats why I think there is an error.
Adeeb
Hey Adeeb,
However it is good to hear that the issue has got resolved.
Please rate the helpful tags it may help others.
Thanveer
You should switch from traditional NAT to NVI:
http://inetpro.org/wiki/NAT:_access_outside_global_address_from_the_inside
this is what i would do in your case:
no ip nat outside
ip nat enable
interface Vlan1
no ip nat inside
ip nat enable
no ip nat inside source list NAT_Addresses interface FastEthernet4.1103 overload
no ip nat inside source static tcp 192.168.1.198 80 49.123.456.7 80 extendable
no ip nat inside source static tcp 192.168.1.198 443 49.123.456.7 443 extendable
no ip nat inside source static tcp 192.168.1.198 8090 49.123.456.7 8090 extendable
ip nat source list NAT_Addresses interface FastEthernet4.1103 overload
ip nat source static tcp 192.168.1.198 80 49.123.456.7 80 extendable
ip nat source static tcp 192.168.1.198 443 49.123.456.7 443 extendable
ip nat source static tcp 192.168.1.198 8090 49.123.456.7 8090 extendable
end
clear ip nat tra *
Hi Francesco,
Thanks for your reply, but your solution cannot solve my problem.
Here is many router show run again:
User Access Verification
Username: xxxxxx
Password:
RP_Router01#show run
Building configuration...
Current configuration : 2520 bytes
! Last configuration change at 12:29:38 SGT Fri Oct 19 2012 by xxxxxx
! NVRAM config last updated at 12:34:16 SGT Fri Oct 19 2012 by xxxxxx
version 15.0
no service pad
hostname RP_Router01
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
   import all
ip cef
no ip domain lookup
ip domain name XXXXX.XXXXX.com.XX
login delay 3
no ipv6 cef
policy-map NGNBN
class class-default
  set cos 1
no ip address
duplex auto
speed auto
ip address dhcp
ip nat enable
no cdp enable
interface Vlan1
ip nat enable
no ip http server
control-plane
line con 0
privilege level 15
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
ntp server XXX.XXX.XXX.1 prefer
end
I was following exactly your command but no idea why still cannot access my public static IP 49.123.456.7 from local network.
Adeeb
What is done by ISP's DNS to resolve the issue? can there be any problem because of that?
Thanveer
Hi Thanveer,
The issue is not resolved yet.
Adeeb
sorry Adeeb, I was confused.
You meant that IP is resolved by DNS of ISP.
It must work with what Mr Francesco given, Can you spare the impact of rebooting the router....
Thanveer
have you tried to reboot the router? It might be required since that change
is quite impacting.
Please let me know if it helps
Hi Francesco,
Yes I can reboot the router later. I shall let you know. Meanwhile here are some of the nvi translations from the router:
tcp 49.123.456.7:443    192.168.1.198:443  ---                ---
tcp 49.123.456.7:2492   192.168.1.198:2492 65.51.162.241:2492 65.51.162.241:2492
tcp 49.123.456.7:8090   192.168.1.198:8090 ---                ---
udp 49.123.456.7:37     192.168.1.199:137  192.168.1.255:137  192.168.1.255:137
My server's are using the 443 and the 8090 port (the one on 8090 is actually a virtual server). The translations work fine with other websites but they cannot translate only the servers from an internal source.
Here are some remote logins from external public IP we have tested:
tcp 202.130.153.152:61510  202.130.153.152:61510    49.123.456.7:443         192.168.1.198:443
tcp 42.68.125.235:36378     42.68.125.235:36378        49.123.456.7:443         192.168.1.198:443
tcp 42.68.125.235:36382     42.68.125.235:36382        49.123.456.7:443         192.168.1.198:443
If there is any other alternative that does not involve restarting the router do let me know. I am not sure when exactly we can reboot the router in the working hour.
Adeeb
i'm not quite sure... you could avoid rebooting trying
clear ip nat nvi translations *
clear ip nat translations *
Dear Francesco,
Can we do
clear xlate [global ip1[-ip2] [netmask mask]] [local ip1[-ip2] [netmask mask]]
[gport port1[-port2]] [lport port1[-port2]] [interface if_name] [state state]
Thanveer
No, that's the equivalent command for pix/asa/fwsm
Francesco
