How do I get a config from shadow to the device?
getwithrob
Level 3
Level 3
RME runs on Unix in this environment. The config files are stored in /var/adm/CSCOpx/files/archive/shadow/Cisco_type.
Ok I have a device called rtr1.domain.com in the directory listed above. I go to that directory on the box. What will the command be to get the config file to the device?
nhabib
Level 9
Level 9
copy the file to /tftpboot
chmod 666 /tftpboot/rtr1.domain.com.cfg
telnet to rtr1.domain.com
copy tftp run
5 Replies 5
nhabib
Level 9
Level 9
copy tftp run
Thank you.
cookia
If the system runs on Windows, is there an equivalent method I can employ?
The same applies to Windows
Simply put the file in CSCOpx\tftpboot
Yep,
Just make sure that "casuser" has suficient rights or is owner of the file.
Cheers,
Michel
