how to automate ssh sessions using the public key instead of the password ?
nlariguet
Level 3
Level 3
can anybody tell me how to automate ssh sessions using the public key instead of the password ?
I can login with ssh#2 to the router without any problem.
I previously generated a pair of dedicated keys for ssh such as:
key name: routerSSH ... pair was generated at: 21:46:53 UTC Sep 10 2009
storage device: private-config
usage: signature key
key is not exportable
key name: routerSSH ... pair was generated at: 21:47:17 UTC Sep 10 2009
usage: encryption key
key name: routerSSH.server ... pair was generated at: 03:33:33 UTC Nov 25 2009
temporary key
I understand I need to grab the public key generated on the router, place it somewhere on my workstation telling PuTTY where it is, and then I should be able to login with -l username but without the password right ?
... problem is I don't figure which one is the public key since they the router states: signature, encryption, and temp encryption key ... so which one should I use ?
... just point to a document telling how to because it seems I cannot find it in the IOS configuration guides
Joe Clarke
Public key authentication is not supported with IOS.  That is, you will not be able to login to an IOS device just using a public key.  You will always need to enter your password.
Joe Clarke
well, at least that explains why I didn't find it on the configuration guides; thanks !
christian.schroeder
Community Member
This is only supported in IOS v15:
http://blog.ioshints.info/2009/10/ssh-rsa-authentication-works-in-ios.html
Cheers,
Christian
I wonder if NX-OS supports SSH pub key auth.
