How to bridge mode G1100 verizon router ? I have ASA 5506 behind the verizon router
How to bridge mode G1100 verizon router ? I have ASA 5506 behind the verizon router. everything was working perfect untill the power went off and then when came back lost internet. called verizon they rest the G1100 router told me to turn off the wireless and should be ok!!  now I can't bridge mode the Verizon router. can someone Please Please walk me through it.
Ammar
Hi there,
It didn't work. it worked fine until the power went off for few minutes and when came back lost internet.  is it something happen to the ASA 5506?
thank you.
Ammar
jacobvanatta
What does your interface configuration look like on the link to the Verizon router?  DHCP or static?  Confirm what the IP address is.  If you're getting a local IP via DHCP from equipment, you may need to go into the router and manually set the IP Passthrough / DMZ.  This is where I would start anyway.
Jake
