How to check the physical interface(s) used by a tunnel interface
morris0117
Greetings,
In my guess, since tunnel interface is a logical interface, it should match one or more physical interfaces. But I tried several commands on a IOS-XE ASR1006 router and there's no output of anyone showing the composition or matching info of this tunnel interface. (please refer to the image attached)
Is my understanding wrong or how can I know which physical interface(s) is used by this tunnel interface?
Thank you very much.
8 Replies 8
M02@rt37
Hello @morris0117
Please share your image.
Best regards
Sorry, I don't know why the image wasn't uploaded. Now it's attached.
The output of "show interface tunnel (number)" will give you the tunnel source interface(where your tunnel traffic logically originates). Which interface will be used for ingress/egress is however determined by regular routing, you will need to inspect your route table to find the entry for the tunnel destination address to see which interface will be used. Alternatively you can use "show ip cef (address)" to find this information.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hi Torbjørn,
The attached image below is how I imagine a tunnel. I think what you're talking about is for example I can check R2's tunnel interface info on R1 with a ip address.
But what I want know is how to show which physical interface is assigned as a "tunnel interface", either on R1 or R2. Also thank you for mentioning "tunnel source interface", it confuses me too. On our router, I see the source interface is loopback 0 instead of a physical interface... Is it similar to the concept of L2MPLS VC using the loopback address as the xconnect destination?
Sorry for making it more complex. What I can see is "tunnel 128 is connecting to the customer", but I want to know the real port connecting to the customer.
Thank you all.
your topolgy is explain why you confuse
you have tunnel and you use LO as tunnel source and you have two path to tunnel destination
you want to see which path (which egress interface) the tunnel use
show ip route <tunnel destination> longest <<- this give you which path router select
NOTE:- if both path same metric the router use load balance
MHM
Hi MHM,
Sorry, I'm not asking about the path or destination of a tunnel. I'd like to know the physical interface being used by this tunnel.
What I can see from "show run interface tunnel128" is:
ip vrf forwarding xxx
ip address 172.x.x.17 255.255.255.248
ip nhrp map multicast dynamic
ip nhrp network-id xxx
tunnel source Loopback0
tunnel mode gre multipoint
tunnel key xxx
tunnel protection ipsec profile X shared
According to internal reference, the customer router is using 172.x.x.18/29.
So it's configured as a normal interface running vrf and ipsec... but how can I know what the physical interface is?
Thank you.
Friend
R1 use loopback as tunnel source
We need to see which physical interface R1 use to reach R2 LO (which is same as R1 tunnel destination)
We use
Show ip route <tunnel destination> longest
This give use the egress interface R1 use to reach R2 LO
MHM
"NOTE:- if both path same metric the router use load balance"
BTW, an additional note, a tunnel's packets are usually seen as a single flow and most often LB doesn't split a flow's packets across multiple egress interfaces.
