How to config Cisco Prime for exactly monitoring
sundayviet
My Cisco Prime is measuring bandwidth ratio base on hard interface's bandwidth. For example, there is 10M current bandwidth on 1G(1000Mb) interface router, Prime show the ratio is 1%. But on this 1G interface, I plug the connection which 100M bandwidth purchase from ISP. So 10M bw is using per 100M should be 10%. Is it possiable to config for Prime to show exactly this?
It very easy to do this in other network monitoring (Cacti, Prtg, ...), but I do not know how to do on Cisco Prime.
0 Replies 0
