How to configure routers remotely
marcusbrutus
Hi Experts,
I recall using some of Cisco's tools where it required me to enter the SNMP RW and enable password to manage core switches similar to a 4507.  With this tool, I am able to set the vlan association of several ports among other things.  From a linux/unix device, is there a way like using snmpget, to run commands like "show ip wccp" for example on a remote router without having to login?
Thanks in advance!!!
Marvin Rhoads
Sure you can snmpwalk a device to retrieve any snmp oid values that are instrumented in the target device. It takes a bit of work to identify the right oid - typically one would research in a MIB browser to ascertain the proper OID and then do the query after having established a local copy of the MIB to help parse the query results into more human-friendly form.
That said, After a short check I was not able to find that or if Cisco has created a MIB for their implementation of WCCP. Bluecoat seems to have one for their devices - see http://ipmsupport.solarwinds.com/mibs/WCCP-MIB/tree.aspx
for example.
Marvin Rhoads
for example.
