How to configure Snmp Trap in switch and monitor in server
Tulasikumar
Hi all,
I want to know how to configure the switch to server to monitor to snmp trap.
Mark Malone
to turn on snmp traps on a switch the command is (conft)snmp-server enable traps
That will turn on every trap or you can chose which ones with ?
If I do the snmp-server enable traps, how do I choose which notifications/traps I want?
You can specify which SNMP traps you want to sent to the server, here is a guide for your reference: https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/13506-snmp-traps.html
Please do not forget to rate useful post.
Best Regards,
CiscOptimist
You can configure SNMPv2c traps quickly with just two commands:
! Enables all traps
!…or select some, for example:
! snmp-server enable traps cpu envmon ospf
snmp-server host 10.1.1.10 public
If you need to configure SNMPv3 then follow this guide:
https://bestmonitoringtools.com/configure-snmpv3-on-cisco-router-switch-asa-nexus-a-step-by-step-guide/
