4 Devices with Same IP Address - 172.17.1.1 - Not sure to make this work
Hi Guys,
Is there any devices for Cisco Products or other vendor that can do 4 unit devices w/ Same IP Address of 172.17.1.1?
Or is there any devices that can do a Port Forwarding for these 4 unit devices w/ same IP if 172.17.1.1?
I am not sure how to make this work as per requirement of our customer.
Thanks in advance.
Erwin
6 Replies 6
balaji.bandi
Not sure what device you have or looking.
you can same IP address in a different segment of the network, that is possible you can do NAT with other IP range
BB
Hi Bandi,
Thanks for the response.
Is that doable if we use a Cisco Switch 6500 That can do NAT or Port Forwarding and connect those 4 Devices w/ the same IP Address(172.17.1.1) to it?
NAT is supported on 6509s anyway , another option may be to use basic VRFs , you can have same ip address in multiple vrfs as there isolated to each other but can speak with each other
yes possible technically.
BB
I think is possible with VRF's since these virtual equipments become independant, and you could also consider using hsrp or glbp so both interfaces can forward packets as they would be different equipments.
Hi Giovanni,
thanks for the response. Is there any specific device that do VRF's? A Firewall or Layer 3 Switch?
Also, for each VRF should have it's own ISP correct?
Erwin
