How to copy a value of interface counter to a variable
danilo.padula
Hi Folks,
I'm new in EEM and I'm trying to read a interface counter and save the value in a new variable. I will use the new variable to manipulate the value.
Should I use SNMP (event snmp oid ...) to get the value?
Padula
5 Replies 5
Joe Clarke
It depends on the counter and how you want your policy to run.  What is the ultimate goal?
Hi Joseph,
I need to read the output packet counter.
We have a problem, that two routers 3845 stop forwarding without any reason.
We investigated with Cisco and didn´t find any BUG that explain the problem. So, I´m trying to make a applet in EEM to colect some commands to start the investigation.
So it's fair to say that if the output packet counter doesn't increase in a given time window you want to raise and event?  What should trigger this policy?
Nothing it will trigger the event. We have to check the counter periodically. For example, one time per hour.
You can use something like this:
event manager applet periodic-cmds
event timer watchdog time 60
action 1.0 cli command "enable"
action 2.0 cli command "show interface gi0/1 | append flash:/output.txt"
action 3.0 ...
Just keep adding the commands you want to run.
