How to delay execution of EEM after another event
pangassam
Hi there,
I am looking for help writing a script that will manually clear an IPSec tunnel 10 minutes after a delete SA message is sent to the console.
Here is the script I have on my router, it doesn't seem to work as I have to complete action 3.1 manually.
event manager applet IPSEC-Cleanup
event syslog pattern "delete SA with .*"
trigger delay 615
action 1.1 regexp "delete SA with .* for ([0-9\.]+)" "$_syslog_msg" match remote-peer
action 2.0 syslog msg "Tunnel with $remote-peer is down"
action 3.0 cli command "enable"
action 3.1 cli command "clear crypto session remote $remote-peer"
Thanks for your help.
Joe Clarke
Have a look at the document I just wrote on this subject:
https://supportforums.cisco.com/document/12723951/how-introduce-large-delays-eem-policies
The idea is that you use another policy to do the long countdown for you.
Joe Clarke
Thanks Joe,
On which eem version you've tested the example shown?
I used your example on my router and I got different output :
Router#sh run | sec event
event manager environment q
event manager applet track-up
event track 1 state up
action 001 cli command "enable"
action 002 cli command "config t"
action 003 cli command "event manager applet track-timer"
action 004 cli command "event timer countdown time 300"
action 005 cli command "action 1.0 cli command enable"
action 006 cli command "action 2.0 cli command $q config t$q"
action 007 cli command "action 3.0 cli command $q int G0/0$q"
action 008 cli command "action 4.0 cli command $q shut$q"
action 009 cli command "action 5.0 cli command $q no event manager applet track-timer$q"
action 010 cli command "action 6.0 cli command end"
action 1.0 cli command "enable"
action 4.0 cli command "shut"
action 6.0 cli command "end"
Dec 8 22:38:36.411: %TRACKING-5-STATE: 1 interface Gi0/1 line-protocol Down->Up
Dec 8 22:38:36.411: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : CTL : cli_open called.
Dec 8 22:38:36.411: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router>
Dec 8 22:38:36.411: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router>enable
Dec 8 22:38:36.423: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router#
Dec 8 22:38:36.423: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router#config t
Dec
Router# 8 22:38:36.435: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Enter configuration commands, one per line. End with CNTL/Z.
Dec 8 22:38:36.435: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config)#
Dec 8 22:38:36.435: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config)#event manager applet track-timer
Dec 8 22:38:36.447: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.447: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router
Router#(config-applet)#event timer countdown time 300
Dec 8 22:38:36.459: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.459: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action 1.0 cli command enable
Dec 8 22:38:36.471: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.471: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action 2.0 cli command config t
Dec 8 22:38:36.483: %
Router#HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : ^
Dec 8 22:38:36.483: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Dec 8 22:38:36.483: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.483: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action 3.0 cli command int G0
Router#/0
Dec 8 22:38:36.495: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : ^
Dec 8 22:38:36.495: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Dec 8 22:38:36.495: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.495: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action
Router#4.0 cli command shut
Dec 8 22:38:36.507: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.507: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action 5.0 cli command no event manager applet track-timer
Dec 8 22:38:36.519: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : action 5.0 cli command no event manager applet track-timer
Dec 8 22:38:36.519: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : ^
Dec
Router# 8 22:38:36.519: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Dec 8 22:38:36.519: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.519: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : IN : Router(config-applet)#action 6.0 cli command end
Dec 8 22:38:36.531: %HA_EM-6-LOG: track-up : DEBUG(cli_lib) : : OUT : Router(config-applet)#
Dec 8 22:38:36.5
Router#
Hi Joe, I forgot to show the EEM version I am run:
Router#sh event manager version
Embedded Event Manager Version 3.10
Component Versions:
eem: (v310_throttle)4.1.23
eem-gold: (v310_throttle)1.0.7
eem-call-home: (v310_throttle)1.0.6
Event Detectors:
The applet will work with EEM all the way back to 2.1.  Looks like you did not define your q environment variable correctly.  What you need to do is:
event manager environment q "
The trailing " is important.
