How to delete a system generated MO - error
blebarro
I received the following error message after trying to delete
a system-port-profile-node-1202.  I created this trying to make port 31-32 access ports on a 100g switch N9K-93600CD-GX.   Error:  Failed to delete object. infraAccPortP uni/infra/accportprof-system-port-profile-node-1202 since it is a system generated MO.   How to I get rid of this as it didn't do what I wanted and it overlaps with leaf 1202 now?   Any help would be greatly appreciated.
I might be completely off here, but these errors usually mean that there is a parent component that keeps you from deleting the port profile. There used to be the command:
N9K-93600CD-GX(config-ppm)# inherit port-profile
I am not sure if you can you the 'no' form to break the inheritance...
