How to disable AAA authentication on LMS 2.6, and enable local user authentication
enaforhmd
After configuring AAA authentication on Ciscoworks 2.6,  I can log on Ciscoworks but with no privileges.
I can view any related ciscoworks shared profiles on Cisco ACS 4.0.1.
After verifying on the web (http://www.conft.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.pdf) if released that I have ommited the configuration sted related to systemiduser.
I would like to set ciscoworks authentication model to local user database, but I don't have provilege to do this;
Is there a suggestion ?
Best Regards.
Nael Mohammad
Level 5
Level 5
Do a "CSCOpx/bin/perl CSCOpx/bin/ResetLoginModule.pl from the cli after stopping CiscoWorks LMS daemon manager.
Nael Mohammad
Level 5
Level 5
Thank you Mohammad,
It works.
Best Regards.
