How to disable FIPS mode on a newly installed Cisco Prime Infrastructure 2.2
fuhrersk8
Level 3
Level 3
Hello Guys;
   Is there a way to disable FIPS mode on a newly installed Cisco Prime Infrastructure 2.2?
Thanks for your support.
marce1000
 - Fips is disabled by default, if it was enabled, then your are out of luck :
Ref : http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/administrator/guide/PIAdminBook/ServerHardening.html#40549
  • Once installed in FIPS mode, there is no way to switch the product to non-FIPs mode, and vice versa. A fresh installation of the product is required to switch to FIPS mode from non-FIPS mode and vice versa.
