how to disable the discovery settings lms 3.2
i am using lms 3.2.where i hav added devices manually.Because discovery settings the device are taking some random ip updating the display and
hostname.
i want disable the full discovery settings..
Channa
AFROJ AHMAD
Hi Channa,
To disable the device discovery :
As per my understanding  there is no direct way to disable the device disovery however you can do this :
Go to Common service >Device Mgmt > device discovery >> click on Sechduled discovery >> Delete the sechduled job if any exist..
To stop the Immediate discovery : just do not define any SEED device in the discovery settings or clear the discovery settings..
Immediate discovery does not ran automatically untill an unless someone Manually ran it..
I hope this will help
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
HI Afroj,
THanks for reply..
IN device discovery>discovery settings>module setttings
when i try uncheck all the options and continue its giving me this error..
i want to disable this also..
I have attached the screenshot.
channa
Hi Channa,
Yes you are right you can not proceed further without selecting a module.However you should not be worried about this settings as this discovery will not ran untill you Manually ran it..
Afroj
