How to enable GUI for a Cisco 1841?
deepthirajt
cadet alain
install SDM or CCP on your PC then on the router :
en
conf t
ip dhcp excluded-address 192.168.1.254
ip dhcp pool MYPOOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
ip http server
ip http authentication local
username xxx privilege 15 secret   xxxx
int f0/0
ip address 192.168.1.254 255.255.255.0
no shutdown
Regards.
Alain.
