How to ensure a variable's character length
rychaney
I am using the divide function and I've found that if the remainder starts with a zero the leading zero is dropped. In my script I want to check if the output of $remainder is 6 characters and if not to add a leading zero, any idea of the best way to do this? I was thinking a regex?
Ryan
Joe Clarke
You can use the string length action for this.
string length $remainder
if $_string_result lt 6
set remainder "0$remainder"
end
Great answer, I didn't know you could do that.
What version of EEM is required for the string length command?
EEM 3.0.
