11-07-2018 08:24 PM
I have a cisco asa 5500 series. From this cisco IOS working from tftp server. I want to format flash card and import configuration file remotely. If it possible If it yes but how i can do it?
Solved! Go to Solution.
11-09-2018 09:15 PM
11-07-2018 08:45 PM
11-07-2018 09:22 PM
What do you mean by format Flash remotely on asa?
It's now Asa is loading from Tftp server. i can connect to asa via putty(remotely).
after connecting to ASA can i format Flash?
Can you describe what you want to achieve please?
I want to format Flash than import IOS file and configure files
I was done backup firewall ASA via ASDM
Connect to the firewall via ASDM, then Tools > Backup Configuration > Browse to a Location to Save the File > If you have certificates to backup, then choose and confirm a password > OK.
and copy show run
11-07-2018 11:41 PM
CiscoASA# erase flash:
or
CiscoASA# format flash:
This command overwrites all files and erases the file system, which includes hidden system files, and then re installs the file system. On Cisco ASA 5500 series security appliances, the erase command destroys all user data on the disk with the 0xFF pattern. In contrast, the format command only resets the file system control structures. When the erase option is used, it deletes all the information related to the licensing. You need to fetch the activation keys in order to retain the licenses on Cisco ASA.
Abheesh
11-08-2018 01:55 AM
I want to format flash: then copy to flash IOS files
i tried copy disk0: tftp
Source filename []? asa942-11-smp-k8.bin
Address or name of remote host []? 192.168.1.10
Destination filename [asa942-11-smp-k8.bin]?
Writing file tftp://192.168.1.10/asa942-11-smp-k8.bin...
%Error writing tftp://192.168.1.10/asa942-11-smp-k8.bin (Timed out attempting to connect)
i try to ping from ciscoASA
ping 192.168.1.10
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/10
BR
Mirzo
11-08-2018 03:03 AM
Hi Mirzo,
This is connection timed out error, do a packet capture and see what happens when you do copy.
Abheesh
11-09-2018 09:15 PM
