How to generate reports using cisco prime infrastructure
tirabor01
Good Day Shantha,
I really appreciate the support thus far.
Please how do I create reports with cisco prime infrastructure?
Kindly state out the steps from Report Launch Pad.
Anticipating your response.
Tioluwani Irabor
AFROJ AHMAD
Hi Tioluwani ,
checked the attached screen shot , hope it answer your query.
Thanks-
Afroz
**Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks a lot Afroz.
You have been of great help.
I kindly need suggestions for a challenge I am faced with on Cisco prime infrastructure.
a description of the problem(s)I am facing with the Cisco Prime device:
  • I can't connect to it via the web management interface
  • It takes several attempts to boot the device... most cases it hangs in the initial stages of booting. At times it is able to boot into console mode.
I would appreciate a swift response.
Kind Regards,
Tioluwani
Hi Afrjo,
According to your method, I just try to run a report.
But I didn't get the report that I want.
The error display said "No data match the specificed criteria for the report"
Did you come cross this isuss? Or what should I do to solve this issue to get a report?
The screenshot as below,
Thanks in advance,
BR
Frank
