How to get Ciscoworks LMS 4.0.1 serial number
rtitaux
How to get Ciscoworks LMS 4.0.1 serial number ? I need that to put the product under mainrtenance, and I can't manage to get it.
Thanks for your help
Roland
2 Accepted Solutions
Martin Ermel
as LMS 4.0.1 is a service pack on LMS 4.0 you need the serial number of your base installation of LMS 4.0.
The serial number for software products is called "PAK" ("Product Authorization Key")
For LMS there are 3 options to get the PAK:
1) the PAK is printed on a paper sheet in the box in which LMS was sent to you. Sometimes it is also printed outside on the box.
2) the mail you received from licensing@cisco.com after the online licensing process includes the PAK;
    the first lines of the email looks something like this:
DO NOT DISCARD THIS EMAIL.
    Product Name          : R-LMS41-1.5K-MR-K9
    Product Description      : Update LMS 4.0 to 4.1 Base download for 1500 devices
    Product Qty          : 1
    Product Authorization Key : 1354Jxxxxxx
    Sales Order Number      : 117yyyyy
    Options Included: No additional features have been selected for this product.
You have received this email because your email address was provided to
Cisco  Systems during the registration process for a software license key file  to the CiscoWorks LAN Management Solution (LMS) software.
3) the license file itself contains the PAK, sourounded by the tags and <\PAK>
the line looks like this:
    1354Jxxxxxx" SIGN=658Czzzzzzzz
if you have access to your LMS server you can find the license file at the following location:
    NMSROOT\etc\licenses\1317812nnnnnn.lic
open it with a text editor and you 'll find the PAK.
___________________________________________________________________________
          [.... just tag your threads
               and support the CSC initiative "CSC Helps Teachers Without Borders" - it's easy ! ]
Michel Hegeraat
Level 7
Level 7
If you open you license file, the LMS20130822124831239.lic file in a text editor you will see something like this:
SERVER licenseServer abcd1234
VENDOR cisco
FEATURE LMS cisco 3.0 permanent 100 \
    VENDOR_STRING=LMS3 HOSTID=ANY \
    NOTICE="201308221248312391 \
   1234J56E789" SIGN=1DCEC2ECB376
The part inbeteen PAK and /PAK is your serial.
Don't bother to try this one.
Cheers,
Michel
Martin Ermel
    Product Qty          : 1
Michel Hegeraat
Level 7
Level 7
VENDOR cisco
Cheers,
Michel
