how to get snmp oid on a device?
Gerard Gacusan
any idea on how to get snmp oid for a particular cisco device cpu, memory, interface etc?
which means, when running a snmp query (maybe snmpwalk?) to a cisco router or switch, it gives the listing of specific snmp oid.
example:
cpu - .1.3.6.1.9.1.4.x.x.x.b
mem -.1.3.6.1.9.1.4.x.x.x.c
I'm trying to associate the oid to a EEM CPU event applet for a Catalyst 6509 SUP720-3B and I can't find the oid for CPU value.
any thoughts? appreciated in advance ...
Robert Pavone
Here is a tech note on how to collect CPU from devices via snmp.
Also, for future reference and a great bookmark, here is the SNMP Object Navigator here on CCO you can use to search for snmp mib objects and tehir associated OIDs.
Rob
Robert Pavone
Rob
thanks for the help...
