how to get the logs for devices in prime
Radhika Nair
I have added devices in Prime but unable to check where the logs are being stored of the device in the Prime.Could someone please help
5 Replies 5
marce1000
 - Basically have the devices configured with a syslog-destination-server being Prime. same for snmp traps , Prime can receive snmp-traps also. Logging events should then be seen in the Alarms section(s) of Prime.
 M.
I have configured the syslog in firewall with prime ip address and then checked the alarm section it shows no results.i refreshed it couple of times.I had already enabled snmp and its working fine
balaji.bandi
have you configured the device syslog to use as Prime Infra ?
BB
Yes i have done that
Look at the events,. can you post from device show loogging output to look is the messages send to Prime ?
BB
