how to install cisco LMS bundle applications
sravan_235
hi all,
please tell us how to install cisco LMS first time.and what sequence we have to follow to install cisco LMS.
I have total 5 cd .so please tell us, in what sequence i have to install.
sravan
Joe Clarke
To add to Nadim's reply (definitely read the quick start and installation guides), we generally recommend the following order:
Common Services
Campus Manager
Resource Manager Essentials
Internetwork Performance Monitor
Device Fault Manager
However, the only real requirement is that Common Services is installed first. All the other apps can really be installed in any order you'd like (you don't even need to install everything). The reason for the above order is that it requires the least amount of rebooting on Windows.
