How to install cisco works 2000 ?
katoleecn
I have a task to install cisco works 2000 on Windows 2000 Pro. I wander how to install cisco works 2000. What I should be prepared to. I think I need some files about it, Who can give me that? Thank you!
marcjone
You can view all the documentation through the following link:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/index.htm
For specific installation information, see this one also:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/comser30/ig_win/prereq.htm#wp1036866http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/comser30/ig_win/instl.htm
You will need to install Common Services first as this runs the web server and administrates the application. You can then install the other modules from there
Hope this helps
Kind regards
Marcus
Thank you for your reply, It's useful to me, but I still cannot solve my problem.
What are the details of the problem ?
