01-12-2010 12:12 PM
The license URL doesn't work anymore, and searching the site doesn't return anything useful about licensing LMS.
http://www.cisco.com/go/license
Has licensing changed? I don't have a PAK only a s/n now.
Solved! Go to Solution.
01-12-2010 12:27 PM
http://www.cisco.com/go/license is redirecting to https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet fine for me. But since you don't have a PAK, you may need to email licensing@cisco.com for further assistance.
01-12-2010 12:27 PM
01-12-2010 12:29 PM
It appears Cisco.com was having problems. None of the "go" links were working. They are now back. You should be able to access http://www.cisco.com/go/license . However, you will need a PAK which should have arrived with the LMS DVD.
01-12-2010 12:53 PM
Well at least it's now showing a proxy error instead of page not found.
No PAK, just a S/N number because of the account. Maybe they're wrong.
Update: S/N = PAK
