Inventory Failed on ASA 5540
Velin Georgiev
I'm using LMS 3.2 with RME 4.3.1
When I try an inventory job on ASA 5540 (software version 8.2) I receive failure with error "Device sensed, but collection failed"
Re-adding the ASA device does not resolve the problem.
I have attached the IC_Server.log
Please, advice!
Joe Clarke
This looks like CSCtd67173.  Development is still investigating this issue on another service request.  I suggest you open a TAC service request so you can put your name in the hat.  It may be possible to get a debugging patch so the root cause of this issue can be identified.
OK, I will open a TAC.
Thank you for the assistance
