04-25-2013 04:53 PM
The problem i'm encountering is that the cellular interface is UP but as of "sh cell 0/2/0 rad" the radio is off. That data is captured today. How am i going to do EEM script for this one? The recent event i'm getting is "Apr 25 11:17:49.881 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN" .
Cellular0/2/0 10.49.180.173 YES IPCP up up
PHILAM-SJA-BR01#sh cell 0/2/0 rad
Radio power mode = OFF, Reason = Unknown
Current Band = None, Channel Number = 0
Current RSSI = -0 dBm
Band Selected = not selected due to invalid band mask
Logs
Apr 24 07:39:56.884 MNL: %LINK-5-CHANGED: Interface Cellular0/2/0, changed state
to reset
Apr 24 07:40:01.884 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to down
Apr 24 07:40:10.516 MNL: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/2 is now UP
Apr 24 07:40:15.896 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to up
Solved! Go to Solution.
04-25-2013 08:00 PM
You can do it using two applets or, if you are running EEM 2.4 or higher, do it with one multi-event applet. If you use multi-events, you need at least EEM 3.0 if you want to add conditional logic. If you want each syslog to cause the same events to happen, then you only need EEM 2.4. To do things in two applets, any version of EEM 2.x will work.
04-25-2013 07:43 PM
It's very easy to react to this syslog message. What do you want to do when you see this problem, though?
04-25-2013 07:51 PM
is it possible to do 2 scripts on each syslog message like as stated below? or it can do it on a single script?
1. Apr 24 07:40:01.884 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to down
2. Apr 25 11:17:49.881 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN
04-25-2013 08:00 PM
04-25-2013 08:16 PM
How to identify which version of EEM I have?
My router is
CISCO2911-SEC/K9 Cisco 2911 Security Bundle w/SEC license PAK
S29UK9-15104M Cisco 2901-2921 IOS UNIVERSAL
Is there some guidelines on how to do multi-events? or to add conditional logic?
04-25-2013 08:28 PM
Here it is btw, is it ok?
04-25-2013 08:37 PM
You have 3.2, so you can do multi-event applets:
event tag syslog1 syslog pattern "LINK-3-UPDOWN: Interface Cellular0/2/0, changed state to down"
event tag syslog2 syslog pattern "CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN"
trigger
correlate event syslog1 or event syslog2
04-25-2013 09:00 PM
For this case, how can i do multi-event applets? Its different from default format on the commands.
04-26-2013 07:24 AM
I don't understand what you're asking. I already provided you the sample event config for multiple events. If you replace your current "event syslog" config with what I posted previously, that will give you one policy that supports multiple events.
