How to monitor FAN on Switch 2960 ?
Seti
Hi !
I don't find the answer on the internet, so, I ask it here.
Can we monitor fans on the cisco 2960 ?
If we can, which OID we should use ?
By advance, thank's for answers.
odd, according mib browser, CISCO-ENVMON-MIB is present on that switch/ version:
https://mibs.cloudapps.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=4186&PlatformSel=361&fsSel=1449
I don't have a 2960 to hand with which to test further.
Have you tried a different software version?
9 Replies 9
Seb Rupik
Hi there,
1.3.6.1.4.1.9.9.13.1.4.1.3  ciscoEnvMonFanState
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.9.13.1.4.1.3&translate=Translate&submitValue=SUBMIT
...this will just tell you the state (as per the sh env command) not the fan speed.
cheers,
Seb.
This OID work really well with a Switch 3750, but when I try to use it with the 2960 (with snmpwalk command) I receive "SNMPv2-SMI::entreprises.9.9.13.1.4.1.3 = No Such Object available on this agent at this OID" ... It's really strange
What IOS image are you running?
I'm connected to the switch with ssh connection, how can I find the version of IOS ?
sh ver
cheers,
Seb.
I run the 15.2.2.E6 IOS version
It seems to be a problem on our switch who don't have this OID for misterious reason. We give up for the moment.
Thanks for your help.
