How to ping repeat in tclsh ( IOS XR)
minhtetsan192
Dear All,
Now I'm facing a little funny issue. That is I don't know " How to ping repeat (500) in tclsh script On IOS XR. I need your suggestion urgently and I'm also have nothing experiment fo IOS XR router. Please fix my issue.
Best Regards,
Min Htet Sam
run tclsh
foreach address {
8.8.8.8
9.9.9.9
} { ping -s Lo0 -repeat 500 $address}
balaji.bandi
This is from my testing, it  was working IOS XR - test and let me know. change the source interface i use loopback1 here
% foreach IP {
1.1.1.1
8.8.8.8
} { ping -c 500 -s lo1 $IP}
BB
what are you trying to do, ping both IP addresses 500 times ?
foreach ip {
8.8.8.8
9.9.9.9
ping $ip repeat 500 timeout 1 }
Yes sir,
I want to ping all IP 500 times. Please check sir.
% foreach ip {
8.8.8.8
9.9.9.9
% Invalid parameter(s)
child process exited abnormally
% foreach ip {
8.8.8.8
9.9.9.9
} { ping $ip repeat 500 timeout 1 }
balaji.bandi
% foreach IP {
1.1.1.1
8.8.8.8
BB
Thanks, Sir. Now My issue was solved.
% foreach address {
8.8.8.8
9.9.9.9
} { ping -s Lo0 -c 500 $address}
Sending 500, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (500/500), round-trip min/avg/max = 1/2/9 ms
Sending 500, 100-byte ICMP Echos to 9.9.9.9, timeout is 2 seconds:
