PI 2.0 configuration archive problems
oizetbegovic
I've got 2 problems with archiving device configurations in Prime Infrastructure 2.0.
1. Configuration archive job status is Completed and Last run status is Success
Looking at Configuration archive results, I see this:
Fetch Running: Success
Fetch Startup: Success
Fetch VLAN: Unsupported operation
Fetch Modules: N/A
Archive: Success
It's a Cisco 7200 router.
Looking at its Configuration archive, I can see just the running config. Startup config is missing.
2. Configuration archive job status is Completed and Last run status is Partial-Success
Fetch Modules: N/A
Archive: Error in archiving for device '3663756'
It's a Cisco 6500 FWSM.
Looking at its Configuration archive, I can't see anything, it says 'No data available'. Both running and startup configs are missing.
Do you have some ideas what is wrong here, why can't I see the configurations?
Saurav Lodh
Level 7
Level 7
Please issue an access list with a permission of accessing the target device from source as Prime and check the hits.
As it can be seen in the oputput I sent, configurations are fetched but I cannot see them in Prime.
I've found the reason why this is happening. In the case when startup and running configs are identical (disregarding lines like 'last configuration change', 'ntp clock-period',...), Prime doesn't show startup config under Configuration Archive, it
just shows the running config.
How you resolved the issue ?
