How to pull correct interface into EEM applet
steve22076
Community Member
                   We have an environment with multiple 2811's, 1941's, and 2821 routers in hundreds of locations.  Depending on the location's needs, the Serial card may be an MFT or DSU type VWIC or HWIC and may be in different slots.  So that I can deploy a standard EEM applet that would apply to the Serial interface servicing the location's T1, I would like to find a way to pull the correct slot/port number of the Serial (or multilink virtual) interface with an existing IP address on it, into an EEM applet.   An example of the applet that simply states the serial slot/port for an MFT interface card is below.   I was thinking of trying to do this by having the applet parse the output of "show ip interface brief" and take the interface that has an IP address in the "IP address" column and begins with the letters either "Mu" or "Se", but I'm not sure how to do this.
existing applet:
event manager applet Serial_if
event tag if_1 interface name Serial0/1/0:0 parameter input_errors_crc entry-op ge entry-val 2 entry-type increment poll-interval 20
event tag if_2 interface name Serial0/1/0:0 parameter input_errors entry-op ge entry-val 2 entry-type increment poll-interval 20
event tag if_3 interface name Serial0/1/0:0 parameter input_errors_frame entry-op ge entry-val 2 entry-type increment poll-interval 20
event tag if_4 interface name Serial0/1/0:0 parameter input_errors_overrun entry-op ge entry-val 2 entry-type increment poll-interval 20
event tag if_5 interface name Serial0/1/0:0 parameter output_errors entry-op ge entry-val 2 entry-type increment poll-interval 20
event tag if_6 interface name Serial0/1/0:0 parameter output_errors_underrun entry-op ge entry-val 2 entry-type increment poll-interval 20
trigger occurs 1
  correlate event if_1 or event if_2 or event if_3 or event if_4 or event if_5 or event if_6
action 100 cli command "enable"
action 200 cli command "config t"
action 300 cli command "int Serial0/1/0:0"
action 400 cli command "shutdown"
action 401 set syslog_msg "CRC failure leased line $_interface_name"
action 500 syslog msg "$syslog_msg"
csc-lab01#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.2          11.17.254.2     YES NVRAM  up                    up
FastEthernet0/0.4          11.113.254.2    YES NVRAM  up                    up
FastEthernet0/0.6          11.113.253.2    YES NVRAM  up                    up
FastEthernet0/0.52         10.17.254.2     YES NVRAM  up                    up
FastEthernet0/0.53         10.17.254.66    YES NVRAM  up                    up
FastEthernet0/0.54         10.17.254.130   YES NVRAM  up                    up
FastEthernet0/0.55         10.17.254.194   YES NVRAM  up                    up
FastEthernet0/0.56         11.81.254.2     YES NVRAM  up                    up
FastEthernet0/0.57         11.170.254.2    YES NVRAM  up                    up
FastEthernet0/1            172.25.248.225  YES NVRAM  up                    down
BRI0/0/0                   unassigned      YES NVRAM  administratively down down
BRI0/0/0:1                 unassigned      YES unset  administratively down down
BRI0/0/0:2                 unassigned      YES unset  administratively down down
Serial0/1/0:0              208.220.209.34  YES NVRAM  up                    up
Loopback1                  1.1.1.1         YES NVRAM  up                    up
Loopback33                 11.3.130.8      YES NVRAM  up                    up
Output I would like to pull the serial interface from rather than it being manually entered in applet:
FastEthernet0/0.2          10.x.x.x    YES NVRAM  up                    up
FastEthernet0/0.4          10.2.x.x    YES NVRAM  up                    up
FastEthernet0/1            172.16.x.x YES NVRAM  up                    down
Serial0/1/0:0              208.219.209.13  YES NVRAM  up                    up
Try:
event manager applet Serial_Get_multiple_if
event none
action 1.1 cli command "show ip int brief | inc ^Se|Mu"
action 1.2 foreach line $_cli_result "\n"
action 1.3 regexp "^(Se[^ ]+|Mu[^ ]+) +[0-9]" $line match intf
action 1.4 if $_regexp_result eq 1
action 1.5   break
action 1.6 end
action 1.7 end
action 1.8 puts "Interface is $intf"
12 Replies 12
Joe Clarke
Excluding the action labels, try this:
regexp "^(Se|Mu[^ ]+) +[0-9]" $line match intf
  break
end
end
That is exactly what I'm looking for. My tests of this have not worked yet.  You can see the test applet I'm using and the output it gives when run below.
event none
action 100 cli command "show ip int brief | inc ^Se|Mu"
action 200 foreach line "$_cli_result" "\n"
action 300  regexp "^(Se|Mu[^ ]+) +[0-9]" "$line" match intf
action 400  if $_regexp_result eq 1
action 500   break
action 600   puts "Interface is $intf"
csc-lab01#event manager run Serial_Get_multiple_if
csc-lab01#
Jul  3 14:13:28 EDT: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul  3 14:13:28 EDT: check_eem_cli_policy_handler: command_string=event manager run Serial_Get_multiple_if
Jul  3 14:13:28 EDT: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
Jul  3 14:13:28 EDT: fh_fd_match_event: re=0x49998100, policyname=Serial_Get_multiple_if, parameters=, get_tty=1
Well, you are missing the "end" actions that I had in my sample code.  You need to add those back in the right place.  The way you have the code written now, nothing would ever print.  You may also need to configure "event manager session cli username USER" if you are using command authorization.  USER needs to be a username authorized to run all of the CLI commands.  You should also try the "show ip int ..." command manually to make sure it's returning the right data.
Thank you, I changed the applet config to exactly as you suggested as shown below, and I received the debug output below when manually executing.  I have aaa turned off for testing.  Thank you very much for you expertise on this.
Jul  8 12:16:38 EDT: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: intf
Jul  8 12:16:38 EDT: %HA_EM-3-FMPD_ERROR: Error executing applet Serial_Get_multiple_if statement 1.8
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_close called.
event none
action 1.3 regexp "^(Se|Mu[^ ]+) +[0-9]" $line match intf
action 1.5   break
action 1.6 end
action 1.7 end
Where is the full debug output?  There should be message above this as well.
Here is everything that my buffer caught.  I can try to narrow the debug event manager all down to specific's If I'm missing something important above this:
Jul  8 12:16:38 EDT: close tag is
Jul  8 12:16:38 EDT: Popping tag off stack
Jul  8 12:16:38 EDT: Pushing tag on to stack
Jul  8 12:16:38 EDT: open tag is
Jul  8 12:16:38 EDT: Name-Value Pair: Name=(pdir) Value=(_event_severity)
Jul  8 12:16:38 EDT: Name-Value Pair: Name=(tcl) Value=(event_severity)
Jul  8 12:16:38 EDT: Name-Value Pair: Name=(pdir) Value=(_none_argc)
Jul  8 12:16:38 EDT: Name-Value Pair: Name=(tcl) Value=(argc)
Jul  8 12:16:38 EDT: EEM: policy_dir xml builtin: name:_event_type value:131
Jul  8 12:16:38 EDT: EEM: policy_dir xml builtin: name:_event_type_string value:none
Jul  8 12:16:38 EDT: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
Jul  8 12:16:38 EDT: EEM: policy_dir xml builtin: name:_none_argc value:0
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_open called.
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : C
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : *****************************************************************
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : *                             W A R N I N G !
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * This computer system and its network are private property and m
ay be       *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * accessed only by authorized users for official use only. Unauth
orized      *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * use of this system is strictly prohibited and may be subject to
criminal   *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * prosecution. All data contained within this system is privately
owned      *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * and may be monitored, intercepted, recorded, read, copied, or c
aptured     *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * in any manner and disclosed in any manner, by authorized person
nel.        *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * THERE IS NO RIGHT OF PRIVACY IN THIS SYSTEM. System personnel m
ay          *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * disclose any potential evidence of crime found on this system f
or any      *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * reason. USE OF THIS SYSTEM BY ANY USER, AUTHORIZED OR UNAUTHORI
ZED,        *
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * CONSTITUTES CONSENT TO THIS MONITORING, INTERCEPTION, RECORDING
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * READING, COPYING, or CAPTURING and DISCLOSURE.
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : csc-lab01#
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : IN  : csc-lab01#show ip int brief | inc ^Se|Mu
Jul  8 12:16:38 EDT: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul  8 12:16:38 EDT: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Jul  8 12:16:38 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : Serial0/1/0:0              208.220.209.34  YES NVRAM  up
           up
Jul  8 12:16:38 EDT: fh_server: fh_io_msg: received msg FH_MSG_CALLBACK_DONE from client 36 pclient 1
Jul  8 12:16:38 EDT: fh_io_msg: EEM callback policy Serial_Get_multiple_if has ended with abnormal exit status of 0xFFFFFFFF
Jul  8 12:16:38 EDT: EEM fms_remote_chkpt_add_event_hist(), data_len = 2980, buf_size = 2992
Jul  8 12:16:38 EDT: fh_send_none_fd_msg: msg_type=18
Jul  8 12:16:38 EDT: fh_fd_none_publish_done: rc=1, re=49997C40
Jul  8 12:16:38 EDT: fh_fd_none_publish_done: rc=1, publish_expired=0
Jul  8 12:16:38 EDT:   sid=57, ptp=0x499990C0, connp=0x4940CB4C
Jul  8 12:16:38 EDT: none_conn_tm_remove: re=0x49997C40, ptp=0x499990C0
Jul  8 12:16:38 EDT: fh_fd_none_conn_tm_free: ptp=0x499990C0
Jul  8 12:16:38 EDT: fh_send_none_fd_msg: sval=0
Jul  8 12:16:38 EDT: EEM: server decrements in use thread: jobid=35 rule id=2 in use thread=4.
Jul  8 12:16:38 EDT: fh_schedule_callback: fh_schedule_callback: cc=4814DC84 prev_epc=495D24F8; epc=0
Jul  8 12:16:38 EDT: EEM server schedules callbacks: policy_type: 2
Jul  8 12:16:38 EDT: fh_schedule_policy: prev_epc=0x00000000; epc=0x00000000
Jul  8 12:16:38 EDT: EEM server schedules scripts
Jul  8 12:16:38 EDT: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 36 pclient 1
Jul  8 12:16:38 EDT: fh_io_msg: received FH_MSG_API_CLOSE client=36
Jul  8 12:16:38 EDT: fh_fd_match_event: re=0x49997C40, policyname=Serial_Get_multiple_if, parameters=, get_tty=1
ay be       *
orized      *
criminal   *
owned      *
aptured     *
nel.        *
ay          *
or any      *
ZED,        *
           up
Try:
event none
action 1.5   break
action 1.6 end
action 1.7 end
Looks like it is working better in that it is not getting the errors on action 1.8, but when I run the event manager applet, I get a blank line, instead of output.   Here is the debug from running the applet in your last post.  Thanks again for the help with this.
Jul  8 18:16:37 EDT: close tag is
Jul  8 18:16:37 EDT: Popping tag off stack
Jul  8 18:16:37 EDT: Pushing tag on to stack
Jul  8 18:16:37 EDT: open tag is
Jul  8 18:16:37 EDT: Name-Value Pair: Name=(pdir) Value=(_event_severity)
Jul  8 18:16:37 EDT: Name-Value Pair: Name=(tcl) Value=(event_severity)
Jul  8 18:16:37 EDT: Name-Value Pair: Name=(pdir) Value=(_none_argc)
Jul  8 18:16:37 EDT: Name-Value Pair: Name=(tcl) Value=(argc)
Jul  8 18:16:37 EDT: EEM: policy_dir xml builtin: name:_event_type value:131
Jul  8 18:16:37 EDT: EEM: policy_dir xml builtin: name:_event_type_string value:none
Jul  8 18:16:37 EDT: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
Jul  8 18:16:37 EDT: EEM: policy_dir xml builtin: name:_none_argc value:0
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_open called.
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : C
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : ****************************************************************
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : *                             W A R N I N G !
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * This computer system and its network are private property and
ay be       *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * accessed only by authorized users for official use only. Unaut
orized      *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * use of this system is strictly prohibited and may be subject t
criminal   *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * prosecution. All data contained within this system is privatel
owned      *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * and may be monitored, intercepted, recorded, read, copied, or
aptured     *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * in any manner and disclosed in any manner, by authorized perso
nel.        *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * THERE IS NO RIGHT OF PRIVACY IN THIS SYSTEM. System personnel
ay          *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * disclose any potential evidence of crime found on this system
or any      *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * reason. USE OF THIS SYSTEM BY ANY USER, AUTHORIZED OR UNAUTHOR
ZED,        *
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * CONSTITUTES CONSENT TO THIS MONITORING, INTERCEPTION, RECORDIN
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * READING, COPYING, or CAPTURING and DISCLOSURE.
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : csc-lab01#
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : IN  : csc-lab01#show ip int brief | inc ^Se|Mu
Jul  8 18:16:37 EDT: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul  8 18:16:37 EDT: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : Serial0/1/0:0              208.220.209.34  YES NVRAM  up
           up
Jul  8 18:16:37 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_close called.
Jul  8 18:16:37 EDT: fh_server: fh_io_msg: received msg FH_MSG_CALLBACK_DONE from client 38 pclient 1
Jul  8 18:16:37 EDT: fh_io_msg: EEM callback policy Serial_Get_multiple_if has ended with normal exit status of 0x0
Jul  8 18:16:37 EDT: EEM fms_remote_chkpt_add_event_hist(), data_len = 2980, buf_size = 2992
Jul  8 18:16:37 EDT: fh_send_none_fd_msg: msg_type=18
Jul  8 18:16:37 EDT: fh_fd_none_publish_done: rc=0, re=49998000
Jul  8 18:16:37 EDT: fh_fd_none_publish_done: rc=0, publish_expired=0
Jul  8 18:16:37 EDT:   sid=58, ptp=0x49998400, connp=0x4940F5CC
Jul  8 18:16:37 EDT: none_conn_tm_remove: re=0x49998000, ptp=0x49998400
Jul  8 18:16:37 EDT: fh_fd_none_conn_tm_free: ptp=0x49998400
Jul  8 18:16:37 EDT: fh_send_none_fd_msg: sval=0
Jul  8 18:16:37 EDT: EEM: server decrements in use thread: jobid=37 rule id=2 in use thread=4.
Jul  8 18:16:37 EDT: fh_schedule_callback: fh_schedule_callback: cc=4814DC84 prev_epc=4A3F7928; epc=0
Jul  8 18:16:37 EDT: EEM server schedules callbacks: policy_type: 2
Jul  8 18:16:37 EDT: fh_schedule_policy: prev_epc=0x00000000; epc=0x00000000
Jul  8 18:16:37 EDT: EEM server schedules scripts
Jul  8 18:16:37 EDT: fh_fd_match_event: re=0x49998000, policyname=Serial_Get_multiple_if, parameters=, get_tty=1
Jul  8 18:16:37 EDT: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 38 pclient 1
Jul  8 18:16:37 EDT: fh_io_msg: received FH_MSG_API_CLOSE client=38
Jul  8 18:17:00 EDT: fh_fd_timer_process_async
Jul  8 18:17:00 EDT: cron_tick: num_matches 0
ay be       *
orized      *
criminal   *
owned      *
aptured     *
nel.        *
ay          *
or any      *
ZED,        *
           up
I shortened to the applet config below and it output the Serial interface correctly.  Am I losing anything by doing it this way?
event none
action 1.21 set intf "none"
action 1.3 regexp "^(Se[^ ]+|Mu[^ ]+) +[0-9]" $_cli_result result intf
OUTPUT:
Interface is Serial0/1/0:0
Debug Output:
Jul  8 19:11:27 EDT: close tag is
Jul  8 19:11:27 EDT: Popping tag off stack
Jul  8 19:11:27 EDT: Pushing tag on to stack
Jul  8 19:11:27 EDT: open tag is
Jul  8 19:11:27 EDT: Name-Value Pair: Name=(pdir) Value=(_event_severity)
Jul  8 19:11:27 EDT: Name-Value Pair: Name=(tcl) Value=(event_severity)
Jul  8 19:11:27 EDT: Name-Value Pair: Name=(pdir) Value=(_none_argc)
Jul  8 19:11:27 EDT: Name-Value Pair: Name=(tcl) Value=(argc)
Jul  8 19:11:27 EDT: EEM: policy_dir xml builtin: name:_event_type value:131
Jul  8 19:11:27 EDT: EEM: policy_dir xml builtin: name:_event_type_string value:none
Jul  8 19:11:27 EDT: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
Jul  8 19:11:27 EDT: EEM: policy_dir xml builtin: name:_none_argc value:0
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_open called.
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : C
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : *****************************************************************
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : *                             W A R N I N G !
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * This computer system and its network are private property and m
ay be       *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * accessed only by authorized users for official use only. Unauth
orized      *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * use of this system is strictly prohibited and may be subject to
criminal   *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * prosecution. All data contained within this system is privately
owned      *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * and may be monitored, intercepted, recorded, read, copied, or c
aptured     *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * in any manner and disclosed in any manner, by authorized person
nel.        *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * THERE IS NO RIGHT OF PRIVACY IN THIS SYSTEM. System personnel m
ay          *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * disclose any potential evidence of crime found on this system f
or any      *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * reason. USE OF THIS SYSTEM BY ANY USER, AUTHORIZED OR UNAUTHORI
ZED,        *
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * CONSTITUTES CONSENT TO THIS MONITORING, INTERCEPTION, RECORDING
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : * READING, COPYING, or CAPTURING and DISCLOSURE.
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : csc-lab01#
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : IN  : csc-lab01#show ip int brief | inc ^Se|Mu
Jul  8 19:11:27 EDT: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul  8 19:11:27 EDT: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : OUT : Serial0/1/0:0              208.220.209.34  YES NVRAM  up
           up
Jul  8 19:11:27 EDT: %HA_EM-6-LOG: Serial_Get_multiple_if : DEBUG(cli_lib) : : CTL : cli_close called.
Jul  8 19:11:27 EDT: fh_server: fh_io_msg: received msg FH_MSG_CALLBACK_DONE from client 49 pclient 1
Jul  8 19:11:27 EDT: fh_io_msg: EEM callback policy Serial_Get_multiple_if has ended with normal exit status of 0x0
Jul  8 19:11:27 EDT: EEM fms_remote_chkpt_add_event_hist(), data_len = 2980, buf_size = 2992
Jul  8 19:11:27 EDT: fh_send_none_fd_msg: msg_type=18
Jul  8 19:11:27 EDT: fh_fd_none_publish_done: rc=0, re=499963C0
Jul  8 19:11:27 EDT: fh_fd_none_publish_done: rc=0, publish_expired=0
Jul  8 19:11:27 EDT:   sid=63, ptp=0x49997940, connp=0x4940BF94
Jul  8 19:11:27 EDT: none_conn_tm_remove: re=0x499963C0, ptp=0x49997940
Jul  8 19:11:27 EDT: fh_fd_none_conn_tm_free: ptp=0x49997940
Jul  8 19:11:27 EDT: fh_send_none_fd_msg: sval=0
Jul  8 19:11:27 EDT: EEM: server decrements in use thread: jobid=48 rule id=2 in use thread=4.
Jul  8 19:11:27 EDT: fh_schedule_callback: fh_schedule_callback: cc=4814DC84 prev_epc=496E31A8; epc=0
Jul  8 19:11:27 EDT: EEM server schedules callbacks: policy_type: 2
Jul  8 19:11:27 EDT: fh_schedule_policy: prev_epc=0x00000000; epc=0x00000000
Jul  8 19:11:27 EDT: EEM server schedules scripts
Jul  8 19:11:27 EDT: fh_fd_match_event: re=0x499963C0, policyname=Serial_Get_multiple_if, parameters=, get_tty=1
Jul  8 19:11:27 EDT: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 49 pclient 1
Jul  8 19:11:27 EDT: fh_io_msg: received FH_MSG_API_CLOSE client=49
Jul  8 19:12:00 EDT: fh_fd_timer_process_async
Jul  8 19:12:00 EDT: cron_tick: num_matches 0 Jul  8 19:11:27 EDT: close tag is
ay be       *
orized      *
criminal   *
owned      *
aptured     *
nel.        *
ay          *
or any      *
ZED,        *
           up
I installed another Serial interface just to verify and the applet only returns the one with the IP address, which is exactly what I needed.  I'm now trying to figure out how to get this output to be entered into my event tags that occur prior to any actions. (So that only the interface that has an IP address is monitored by the EEM applet)  Is there a way for an action to occur before the event tag to define a parameter, or can another EEM script define a value for a this one?
trigger occurs 1
You can have one applet configure a second.  It's called nesting.  Just make sure to define the following environment variable, then replace any nested quotes with $q:
event manager environment q "
For example:
action 010 cli command "action 200 cli command $q config t$q"
Instead of break, it may have worked if you did a goto 1.8.  In Tcl,  the break would have worked.  It should have worked in applet syntax,  too.  Note: you may need to add the following on some configurations:
action 1.0 cli command "enable"
