How to receive 2 or more IP from interface ???
Oleg Gnedykh
!Buenas deas Amigos! I want to get from interface all IP addresses. For example I have vlan xx sh run int vlan xx interface VlanXX ip address 172.16.1.1 255.255.255.0 secondary ip address 10.10.10.1 255.255.255.0 secondary ip address 192.168.1.1 255.255.255.0 I have created EEM Applet event manager applet getip event none sync yes action 1.0 cli command "enable" action 2.0 cli command "sh run int vlan 11" action 2.2 regexp "ip address ([0-9\.]+)" "$_cli_result" _match _ipadd action 2.3 puts "$_ipadd" So I have got ONLY FIRST IP address 172.16.1.1 Dear ALL help me PUTS all addresses from the script . PLEASEeeeee
You can iterate:
action 2.1 foreach line $_cli_result "\n"
action 2.2 regexp "ip address ([0-9\.]+)" "$_cli_result" match ipadd
action 2.3 if $_regexp_result eq 1
action 2.4 puts $ipadd
action 2.5 end
action 2.6 end
Oleg Gnedykh
Sorry Its stupid Cisco BUG !
Buenas deas Amigos!
   sh run int vlan xx
   interface VlanXX
      event none sync yes
You can iterate:
action 2.5 end
action 2.6 end
Thank you Joseph !!!
The key "\n" is wonderful  :-)
I attempted to use "foreach" but without "\n"
