06-24-2022 11:42 AM
Friends
I want to recover the admin password and i follow the procedure of recovery password but the keys for break the boot process doesnt works.
There are the keys that i was using
CTRL ] ,, CTR L , CTR C , ESC
I need to reach the boot loader prompt for change the admin password
Thanks in advance
06-24-2022 04:08 PM
can you follow this guide, please write in which step you stop if you failed.
06-27-2022 07:48 AM
Hello Friends i cant break the boot of the switch i follow the procedure in the power cycling step 1 i try with CTRL ] but i cant stop the boot and enter to the boot loader prompt and change the password
06-27-2022 09:29 AM
- Your actions are not detailed enough described , check https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/b_nx_os_pwr/nx_os_pw.html#47798 , you can for instance only use CTRL ] on switch login: prompt. Provide screenshots or console logs of what is being tried and what is happening before that (too).
M.
06-27-2022 09:38 AM
from doc. I share
"If you are using a non-U.S. keymap, the key sequence that you need to press to generate the break sequence may not work. In this case, we recommend that you set your terminal to a U.S. keymap. You can enter Ctrl-C instead of Ctrl-] (right square bracket) due to keyboard mapping."
