how to scp a file in 7600 using EEM/Tcl
nikos_skalis
Hello All,
I have a Tcl file on 7600 that produces a file, and I would like to copy this file to a server using scp.
This is how the file looks like :
::cisco::eem::event_register_none maxrun 240
#::cisco::eem::event_register_timer cron cron_entry "*/5 * * * *" maxrun 240
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [ event_reqinfo ] ;
if [ catch {cli_open} rc ] {
       error $rc $errorInfo
} else {
       array set clifd $rc
set          filename          "IOS7600.dat_12345" ;
set     transfer        "copy disk0:/" ;        append transfer $filename ;     append  transfer " scp://username:password@ip:" ;
if [ catch {cli_exec $clifd(fd) $transfer} rc ] {
if [ catch {cli_close $clifd(fd) $clifd(tty_id)} rc ]  {
The problem is that scp: hangs ! Could you please help me to work-around this ? What am I doing wrong ?
Many Thanks.
Kind Regards,
Nikos
nikos_skalis
An alternative would be to write an applet, like :
event timer cron name PUSH-CoPP cron-entry "*/5 * * * *" maxrun 240
to do the following command :
but how can I provide the filename, I could use a regexp like :
*IOS7600*
and then answer the related to scp dialog using action statements.
Could you please help me with this please ?
Many Thanks.
Kind Regards,
Nikos
file prompt quiet ... works
