Where is LMS 4.0 Detailed Device View ?
Steve Prescott
Can someone tell me how to get the Detailed Device View in LMS 4.0 please?
From what I have been able to find out I should be able to go do Monitor> Fault Settings> Setup> Fault Device Details, select a device, click View and then click the device name link.
Unfortunatly the device name(s) displayed are not links, just text.
I need to get the the Detailed Device View so that I can block certain interfaces/events from generating alarms, specifically ISDNB channels when voice calls are made.
Steve
Marvin Rhoads
I just checked mine and following the navigation you noted above it works for me - I can navigate down to unmanage individual interfaces. See the screenshot below.
FWIW, I am running LMS 4.2.2 on soft appliance and am logged in as admin.
Thanks for the reply Marvin.
I am running 4.0, but logged in as admin. Maybe its a bug specific to 4.0.
SOLVED IT - Domain had changed but LMS still had old domain suffix against the devices. Corrected that and it is now a link to the Detailed Device View
Is there no way to mark your own threads as ANSWERED ?
