le 12-04-2018 02:05 PM
Is there a way to send Ctrl character using EEM's cli command action? e.g. ^C, ^^x
Résolu ! Accéder à la solution.
le 12-04-2018 02:36 PM
Answering my own question. I found that I can enter "Ctrl-V" and then followed by the special character and it will work. The config also survives a reload. It is not as good as using escape characters like '\003' but nonetheless a serviceable solution.
le 12-04-2018 02:23 PM
Can you post the use case here for that special characters required in the script. so suggestion can be made based on the usage is possible or not, or any limitations.
le 12-04-2018 02:47 PM
Thank you for your feedback and solution, if it solve close the case as helpfull for other.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
