How to send specific traps to a specific snmp server
ronaldobf
Hi guys.
Today I got a request to insert an equipment to our monitoring system.
The customer already has its monitoring system with its configuration.
Since I only manage the WAN, I would like to make polling and also get traps for only a specific BGP peer and the WAN interface.
For polling, I know I can use the snmp view, but for trap generation, how can I prevent my monitoring system to receive unnecessary traps (the ones I am not interested to and the customer still needs it in order to monitor all the equipment).
example:
Customer has its monitoring server in order to receive all the traps related to interface, CPU, internal routing protocol states, environmental traps, etc and I only need to receive traps for a specific interface, a specific BGP peer.
Thanks in advance
Vinod Arya
I dont think there is a way to control Traps per interface wise.
For sending specific traps to a perticular snmp-server we can use trap names after the host command :
snmp-server host
snmp-server host x.x.x.x public bgp .. .. .
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
snmp-server host
-Thanks
Got it. That´s what I thought.
Thanks.
snmp-server host
-Thanks
Do you have to first enable the specific trap and then point it to a host?
Example:
snmp-server enable trap cpu
snmp-server host user1 192.168.1.1 cpu
