How to set(change) max bandwidth on switch using SNMP
hanjs
Hi, I'm new to SNMP and trying to change the bandwidth for specific port on switch.
I could change the bandwidth for specific port with CLI.
Now I'm trying to do the same using SNMP. However, OIDs I've tried were all 'read-only' so I can only get the bandwidth for each port: I mean I can't change the bandwidth.
Is there any OID that can 'write' bandwidth? Or any other way to change the bandwidth using SNMP?
Model of the switch is
WS-C3650-24PS-S
balaji.bandi
not sure what bandwidth you like to configure? what is the use case here?
check SNMP read-write OID
http://www.net-snmp.org/docs/mibs/interfaces.html
check below OID :
1.3.6.1.4.1.9.5.1.4.1.1.9
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=portAdminSpeed
BB
which CLI command equivalent do you want to change by using SNMP ?
